5 members (UtahYork, Gdads51, Cletus1950, Hotrod Lincoln, MickeyP), 81 guests, and 3 robots.
Topics128,150
Posts1,056,985
Members48,460
#1213484 04/17/2017 6:03 AM
So I just bought a 1950 Chevy 3800 ... love the 9' bed! It came with a spare tire/rim, and the guy I bought it from just had it laying in the bed.
Anybody know how that spare tire was originally mounted from the factory? I'm assuming it was mounted in the bed (plenty of room back there) or maybe it was mounted on the side, but either way I can't seem to locate any old pics that show it. I'd love to locate some original (or at least aftermarket) hardware to have it installed how it was meant to be.
Also love to get a hubcap for it too ... :D
Any ideas?
Did you ask in the 1 ton forum? Jeffrey
And welcome.
deathvalleydog,
I also have a 1950 Chevy 3800, the 9' beds are great. On mine, the spare tire is mounted below the bed in the back. It has two straps that are channel shaped (in cross section) These hang from four 1/2" diameter eyebolts that are fastened to the frame members. The Factory Assembly Manual shows what I'm trying to describe but on the 1.5 ton trucks. But every 1 ton I have ever seen has the same setup as I described for my truck. I think around 52 or 53 they offered a side mount spare for these 9' beds. I do have the correct parts for mine (currently off of the truck). It's a little difficult changing tires on these 1 tons just due to the weight of them.
Good luck with your truck!
Tom
On my 1 ton there is a mount on the passenger box side.
Good luck finding original hub caps. I have 2 spares both pretty beat up 1 painted and 1 chrome.
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
Mine was on the passenger side of the bed as well - http://s1290.photobucket.com/user/j...20Truck/4938003_zpsrrqegzkx.jpg.html?o=2
1952 Chevy 1/2-Ton 3100
1949 Chevy 3800 1-Ton
1953 Chevy 3600 3/4 Ton
More pictures on Photobucket
Thanks for all the advice, everyone! (yeah ... actually got moved to the one-ton forum ;)
I think if I can get a hub-cap I might mount it in the outside of the bed ... it would look nice there. Otherwise, maybe underneath where it was OEM. If I can figure out the photo thing I'll post some pics :)
1949 .. Did it appear that is was an OEM mount? Or did it look aftermarket? Or could you even tell? wink
Probably aftermarket but it certainly looks like it was a common way of dealing with the spare tire. It's my personal preference versus under the bed.
I don't suppose you have a photo of that mount, do you? I've been looking on-line and I see a lot of different things purported to be "mounts", but nothing specific as to how it actually all fits together mechanically.
I have a 54 3800 flat bed, check out my pictures in photo bucket.
http://s1288.photobucket.com/user/richardO54/library/?sort=6&page=1
there is one photo of the spare tire mounted.
Richard
Thanks! I'm looking to mount mine on the side, if possible. Getting too old to crawl under there .. wink
Anyone - any Luck on the 19.5 Rims
I have looked at Extensively and Not even Many 1 Tons have the 19.5's were they an HD Option ?
8 Lugs ?
only seem two others so Far ..
Your life is made up of Two Dates and a Dash........make the most of the Dash.
http://www.fossilcars.com/chevrolet/1-ton-pickup/869217
I don't think 19.5's were available on the AD trucks. My 3800 came with 8 lug 700-18's and I am changing to 8R-19.5's (changing axles too) as that is pretty close to the same size and more availability.
Moderated by  Dusty53
