9 members (wilbur53, Otto Skorzeny, Greg_H, 68ironhead, WICruiser, Gdads51, Shade Baby, rinemb, 1 invisible),
243
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,075 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Test fitting the front end for my 70 1/2 ton GMC before I move to finish work and painting them and wondered how some one else has gone about it. The front clip is all aftermarket parts. I started last night by mounting the radiator support and inner fender wells. Then I tried hanging a fender and what a joy trying to line up the holes to the inner fender well. I was thinking of trying to assemble the inner well and fender as one first and then hang it on the truck?
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I haven't tackled my 70 that I received in a million pieces, but I know on my 50 and 53 that it is easier (for me anyway) to install the outer on the inner and then put on the truck. Make sure you have a couple helpers though to avoid dings. Make sure everything is VERY loose. Have a tapered pin to help you line things up by inserting into various bolt holes. It's also a big help to remove the front wheels to give you lots of workspace if installing the fenders as a pair or group.
| | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | I had already gone ahead and mounted the fender and inner fender as one. I had to enlarge alot of holes so I could float the aftermarket panels around. I test fit the hood yesterday which is the only factory part of the entire front clip and it's fitting up surprisingly well. Biggest modification was to the fenders. They lined up with the door edge at the top and bottom and rocker panel well. But in the middle of the door they stuck out further. So I had to cut the bracing behind the fender so I could push the center of fender in to match the door contour and then welded the brace back up. Today I will test fit the grill assembly and the bumper. Once it's all worked out, disassemble it all and paint.
