0 members (), 166 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#1214254 04/22/2017 10:11 PM
Can you point me in the right direction for floor panels and kick panels? Which ones do you all think are best?
Thanks for you help
Todd
1950 Chevrolet 3100 Pickup
Have the floors and cowl patch panels but haven't tackled the job yet, so can't comment on the quality, but they look good. I have used rear fender front patch panels from Jim Carter and they were good quality. I got the floor panels from Classic Industries because JC didn't have the ones with the toeboard. The rest of the stuff I got from JC.
I bought my floor panels from LMC, I believe...the price was right and the quality seems fine. I installed the right side one and the fit wasn't absolutely perfect (about 1/8" off on one side), but it was pretty darn close. You'll need to buy a cab mount kit that has the extra large dished washers with it, because the floor panels usually do not include the doubler washer where the front cab mount bolt goes through.
~ Dave
I just recently did this work. I bought my patch panels from Classic Parts. The quality of the individual panels was very good. Installing them was another story. Fitting the two panels together at the floor seam was the challenge. Mine required some reshaping and welding in some additional metal to fill the gaps. I have seen other posts that indicate that this is not an uncommon problem.
While most patch panels come with extra length to them, these aftermarket floor halves come up short in the middle where the transmission cover goes. You will need to put the cover in place to check for fitment, then weld in what they shorted you.
Thanks to everyone for the help.
Todd
