| | | Forums66 Topics128,078 Posts1,056,039 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 6 New Guy | | New Guy Joined: Mar 2017 Posts: 6 | Can you point me in the right direction for floor panels and kick panels? Which ones do you all think are best? Thanks for you help
Todd 1950 Chevrolet 3100 Pickup
| | | | | Joined: May 2015 Posts: 11,063 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,063 | Have the floors and cowl patch panels but haven't tackled the job yet, so can't comment on the quality, but they look good. I have used rear fender front patch panels from Jim Carter and they were good quality. I got the floor panels from Classic Industries because JC didn't have the ones with the toeboard. The rest of the stuff I got from JC.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | I bought my floor panels from LMC, I believe...the price was right and the quality seems fine. I installed the right side one and the fit wasn't absolutely perfect (about 1/8" off on one side), but it was pretty darn close. You'll need to buy a cab mount kit that has the extra large dished washers with it, because the floor panels usually do not include the doubler washer where the front cab mount bolt goes through.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Jun 2016 Posts: 182 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 182 | I just recently did this work. I bought my patch panels from Classic Parts. The quality of the individual panels was very good. Installing them was another story. Fitting the two panels together at the floor seam was the challenge. Mine required some reshaping and welding in some additional metal to fill the gaps. I have seen other posts that indicate that this is not an uncommon problem. | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | While most patch panels come with extra length to them, these aftermarket floor halves come up short in the middle where the transmission cover goes. You will need to put the cover in place to check for fitment, then weld in what they shorted you.
| | | | | Joined: Mar 2017 Posts: 6 New Guy | | New Guy Joined: Mar 2017 Posts: 6 | Thanks to everyone for the help.
