1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | Any thoughts re powerglide trans? I have a 40 chevy 3/4 ton with a 57 235. I know I will need to swap out my torque tube drivetrain. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Powerglides come in two versions- - - -1950-62 or so had a cast iron case, and some of the early ones actually worked with torque tube rear ends. They had two of everything- - - -too slippy, too heavy, too troublesome, and two speeds- - -too low and too high.
1963-up Powerglides had an aluminum case, were much smoother-shifting, a lot stronger, and would make a better choice for swapping, but they won't bolt up to a 235 without an adapter, and they're still only a 2-speed. A Turbo 350 or a 700-R4 would be a better choice for a swap. Jerry
| | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | Thanks Jerry. The more modern trannys sound like a better choice. | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I could not imagine driving mine with a Powerglide and a 235. The T5 makes it run so much better, its like a perfect match. The 200R4 or 700R4 would probably be good.
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | Chad, is the T5 a simple installation? I know I will need to have a driveline built. My truck is a 3/4 so the wheelbase is 123 and it now has a 2 piece torque tube with 3 speed trans. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | crowejam, you need to check out "lugnutz" as I feel he is the T-5 guru and has extensive write ups, and tips, on this very tranny. | | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Yes it was very easy. Lugnutz helped me a lot, he is a great asset. He has a GREAT tutorial on his website.
I cannot say enough good things about the T5 behind a 235 engine. My truck is a 1 ton so I had an Eaton HO52 rear end and open driveshaftm That will be your toughest challenge if you have a torque tube setup.
| | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | Thanks Chad. I went on Lugnutz website and I agree, he lays it all out for us. I think the T5 is probly what I will do. I want to get rid of my torque tube and get better highway speed too. | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | If Chevrolet had come up with a T5 in the '40s, the other automakers would not have sold one truck. It brings the inline 216/235/261 to life. No more high revs before a shift, followed by extended periods of lugging the engine. Every time you shift gears, you are in the optimal range of the power band for these engines.
| | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | Thanks for those pics. Very nice work! | | |
