| | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | I'm wanting to try to start the truck by bypassing the key in the cab. We have some major wiring issues that need to be addressed (re-wire in order) and I really don't want to energize the whole system. I purchased a remoter starter switch (two alligator clips, hand held switch) that I was hoping to act as the key being turned on in the cab. My son will still use the stomp start in the cab, but when I flip the remote start switch on, it will energize the coil. It this done by simply connecting one clip to the positive battery terminal and the other clip to the + side of the ignition coil? Do I need to run a jumper wire from the starter to the coil also?
Thanks in advance. Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, run it from battery to coil. No wire from starter. | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Ron and Ryan Hill 1952 Chevy 3100 | | |
