Brrrr
place holder
4 members (Otto Skorzeny, 52Carl, BC59, 1 invisible), 85 guests, and 5 robots.
Topics128,271
Posts1,058,417
Members48,485
#1212900 04/13/2017 5:51 AM
Hello all, just finished installing my rebuilt SM420 using Novak kit.
Everything went well, but I have a few issues
Before connecting the driveshaft, I have her a start to make sure everything was smooth. In neutral, I see the u-joint connector on the back of the tranny spinning a little. Clutch feels great, smooth shift all gears
But when I put in reverse, the u-joint connector rotates the same direction as 1st and 2nd
Also, when I did connect the u-joint, and in neutral, it act like it's in gear and I cannot push the truck
I did install new shift bushing and I think I read that the problem may be in the tranny cover with the rods not being aligned. I plan to call Novak tomorrow, but if anyone has advice before that it's much appreciated
1949 Chevrolet 3100 Suburban Carryall
"Bad Guy"
More pix in Photobucket
1950 Chevrolet 3100 3-Window
More pix on Photobucket
1966 GMC Suburban Carryall Custom
"Big Guy"
Big Bolt Forum Moderator
I would pull the bolts out of the top cover and see if you can lift it a tad and see if the shift forks are where they need to be. It sounds like something is not lines up properly.
with the top off, you should be able to make sure it is in neutral and spin the rear yoke by hand.
Mike
Fox Offline
Lou,
I have a similar problem with my 420 where it rotates in neutral at the output shaft. My sneaking suspicion at the moment is the pilot bearing is egged from my installation. It was a bear to push into the crank and I think it's pinched. I'm going to pull the bearing and the 420 and try an old spare to see if it is the culprit. But for now I'm still sanding, sanding , sanding!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Crusing in the Passing Lane
Pilot bushings are cheap, way less than the grief caused by improper installation, check it upon first trans. Installation when it is easy to replace. Do a test fitting with a spare input shaft.
Ed
Got it up and running today
Wrestled with the cover and smashed my finger by the shift did
Drove around for a bit
Very smooth and well worth the clutch and rebuild
"Bad Guy"
"Big Guy"
I've had my Novak sm420 for over a year it's great. Had the rear end changed to 3:38 new u- joints and drive shaft and clutch assembly. Couldn't be happier Novak is a great company and nice people.
Steve
