| | | Forums66 Topics128,115 Posts1,056,623 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 47 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 47 | Howdy!
Have one of the above on my 59 Burb. Looks to be fairly functional except for worn out lower rubber bushings, bent links and I will assume worn out rubber bushings in the link lollypops.
Has anyone ever found suitable sized replacements and renewed the lower bushings and replaced the lollypop links with modern style links?
Or might I be better off going with a CPP front anti sway kit? Thoughts?
Thanks!! Maddog | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | In my experience, all bushing are not created equal so avoid the J.C. Whitney and a few others that offer them and get a kit from one of the "reputable" vendors. Just my .02 | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Maddog;
I have the exact same issue on my 58 Burb. I'm very interested in what you find out. Nothing on mine is bent but the bushings are toast.
Larry
