Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Guitplayer, KEVINSKI, SmalltownTRKGuy, Otto Skorzeny, UnclePaddy, TGP), 134 guests, and 6 robots.
Topics128,281
Posts1,058,461
Members48,490
Wonder if anyone has tried Bars Leak hydraulic jack oil with stop leak on these shocks and if they had success stopping a shaft seal leak? This is on the rear shocks of my 1949 3100. Thanks
Ed
Once they start leaking around the shaft, the only real fix is to disassemble the shocks and replace the seals. Dirt and grime over the years along with wear degrades the seal. You can try a heavier weight hydraulic oil like Lucas trans stop leak or power steering stop leak. I did....but they still leaked. Apple Hydraulics is the way to go.
Tim
1970 VW Beetle
Unless there's a lot of abrasive dust involved (gravel road travel frequently, etc.) most seals fail because the bushing or bearing BEHIND the seal wears and lets the shaft it's sealing bounce around. No lip seal is going to be able to keep a tight contact with a moving target. That's why I would never attempt to install a pump seal on an automatic transmission unless the customer also agreed to replace the converter support bushing.
Thanks for the inputs. Before I go the rebuild route I think I'll try the stop leak and keep expectations low. For $4.00 nothing to lose.
Ed
