| | | Forums66 Topics128,163 Posts1,056,921 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 5 New Guy | | New Guy Joined: Apr 2017 Posts: 5 | So I just bought a 1950 Chevy 3800 ... love the 9' bed! It came with a spare tire/rim, and the guy I bought it from just had it laying in the bed.
Anybody know how that spare tire was originally mounted from the factory? I'm assuming it was mounted in the bed (plenty of room back there) or maybe it was mounted on the side, but either way I can't seem to locate any old pics that show it. I'd love to locate some original (or at least aftermarket) hardware to have it installed how it was meant to be.
Also love to get a hubcap for it too ... :D
Any ideas? | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Did you ask in the 1 ton forum? Jeffrey
And welcome. | | | | | Joined: May 2011 Posts: 194 'Bolter | | 'Bolter Joined: May 2011 Posts: 194 | deathvalleydog,
I also have a 1950 Chevy 3800, the 9' beds are great. On mine, the spare tire is mounted below the bed in the back. It has two straps that are channel shaped (in cross section) These hang from four 1/2" diameter eyebolts that are fastened to the frame members. The Factory Assembly Manual shows what I'm trying to describe but on the 1.5 ton trucks. But every 1 ton I have ever seen has the same setup as I described for my truck. I think around 52 or 53 they offered a side mount spare for these 9' beds. I do have the correct parts for mine (currently off of the truck). It's a little difficult changing tires on these 1 tons just due to the weight of them. Good luck with your truck! Tom | | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | On my 1 ton there is a mount on the passenger box side. Good luck finding original hub caps. I have 2 spares both pretty beat up 1 painted and 1 chrome.
| | | | | Joined: Jan 2014 Posts: 9 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 9 | | | | | | Joined: Apr 2017 Posts: 5 New Guy | | New Guy Joined: Apr 2017 Posts: 5 | Thanks for all the advice, everyone! (yeah ... actually got moved to the one-ton forum ;)
I think if I can get a hub-cap I might mount it in the outside of the bed ... it would look nice there. Otherwise, maybe underneath where it was OEM. If I can figure out the photo thing I'll post some pics :) | | | | | Joined: Apr 2017 Posts: 5 New Guy | | New Guy Joined: Apr 2017 Posts: 5 | 1949 .. Did it appear that is was an OEM mount? Or did it look aftermarket? Or could you even tell?  | | | | | Joined: Jan 2014 Posts: 9 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 9 | Probably aftermarket but it certainly looks like it was a common way of dealing with the spare tire. It's my personal preference versus under the bed.
| | | | | Joined: Apr 2017 Posts: 5 New Guy | | New Guy Joined: Apr 2017 Posts: 5 | I don't suppose you have a photo of that mount, do you? I've been looking on-line and I see a lot of different things purported to be "mounts", but nothing specific as to how it actually all fits together mechanically. | | | | | Joined: Apr 2017 Posts: 5 New Guy | | New Guy Joined: Apr 2017 Posts: 5 | Thanks! I'm looking to mount mine on the side, if possible. Getting too old to crawl under there ..  | | | | | Joined: May 2017 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: May 2017 Posts: 20 | Anyone - any Luck on the 19.5 Rims
I have looked at Extensively and Not even Many 1 Tons have the 19.5's were they an HD Option ? 8 Lugs ?
only seem two others so Far .. | | | | | Joined: Jun 2015 Posts: 68 'Bolter | | 'Bolter Joined: Jun 2015 Posts: 68 | I don't think 19.5's were available on the AD trucks. My 3800 came with 8 lug 700-18's and I am changing to 8R-19.5's (changing axles too) as that is pretty close to the same size and more availability. | | |
