9 members (GRNHydra, 1955 1 Series, NAPCOStormTrpr, joe apple, Charles in CA, klhansen, DBJ71SuperCustom, dt235sd, 1 invisible), 101 guests, and 2 robots.
Topics128,079
Posts1,056,286
Members48,441
#1212975 04/13/2017 11:25 PM
Looking for an inexpensive way to put a gas tank underneath my 53 GMC 1/2 TON Longbed
cuda #1212999 04/14/2017 4:15 AM
I've read that Reproduction 65/66 Mustang tank fit well.
cuda #1213141 04/15/2017 3:47 AM
back yard wrench turner
I used a Mustang tank
click
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
cuda #1213523 04/17/2017 3:48 PM
This response has to do with the filler neck to the new tank location that some forget about.
A car friend located a new under bed tank on a Studabaker truck and his new filler neck had a number of bends to reach the original filler hole. He had a trick up his sleeve I had never seen before.
He took a piece of scrap heater duct hose and bent it to the configuration he needed. He then filled the duct hose with that 'insulation in a can'. He let it harden, removed the hose, then took it to a muffler shop and they bent a piece of pipe to match it. It looked N.O.S.
I filed that trick away in the old memory bank for the future.
cuda #1213535 04/17/2017 5:15 PM
I've seen Isuzu Trooper and Suzuki Samari tanks work quite well too.
The have 11, 14, and 18 gallon tanks depending on the model.
post #8
http://67-72chevytrucks.com/vboard/showthread.php?t=632697
post 44
http://67-72chevytrucks.com/vboard/showthread.php?t=597180&page=2
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
