1 members (Russ_B_10), 91 guests, and 2 robots.
Topics128,050
Posts1,055,643
#1210434 03/27/2017 4:39 AM
I am currently working on getting the brakes right on my '48 1-ton. In the process, I found that my spindles are ridiculously floppy. My first thought was to put new Kingpins on it. However, when I got the old ones out, they still have some play within the bore on the axle.
That doesn't seem right to me but is it normal? If not, how do I go about fixing it? I don't see anywhere I can get oversize kingpins. Do I need to start looking for JY axles or a machine shop to ream and sleeve mine?
Aaron V.
1948 Chevrolet 3800 216/4-spd
1979 Chevrolet C30 Ramp Truck 454/TH-400
1995 Jeep Cherokee 4.0/5-spd
1970 Ford F100 390/4-spd
1973 Ford Maverick 302/C4
2004 Honda Shadow 1100
"While driving yesterday I saw a banana peel in the road and instinctively swerved to avoid it᠁thanks Mario Kart."
Aaron #1210435 03/27/2017 5:04 AM
Offline
Offline
The wedge pin holds the king pin stationary in the axle. If you are just placing the pin in the axle without the wedge pin, it is not a true indication of whether or not it will incur any play. If you install the wedge pin and there is still play, then yes, you have a problem!
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
Aaron #1210436 03/27/2017 5:37 AM
I first discovered the play when I took off the brake drum and at that point everything (including the wedge pin) was assembled.
I actually just came across AC Delco P/N: 45F00134 which looks like a .020" oversize Kingpin. I think I will order those and find a machine shop that will ream my axle and spindles.
To think, all this started with me trying to get the stack of new wheels and tires out of my garage and onto the truck but turned into new wheel cylinders, brake lines, wheel bearings, kingpins, and shocks dang
Aaron V.
Aaron #1210448 03/27/2017 12:33 PM
My experience with my 1 Ton was that if the holes in the axle are the least bit sloppy, the wedge will only hold it tight until you drive down the road. If the pin drops out of the axle by itself, you have a problem. I took my axle to a machine shop and they installed hardened steel bushings in the axle and brought it back to standard.
1951 1 Ton Completed
Aaron #1210452 03/27/2017 1:06 PM
correct, the proper fit is a snug slip fit, might take a few whacks with a rubber mallet to get them in, could possibly do it with firm palm pressure.
Falling out is a problem, loose fit.
the lock bolt is not going to to "improve" the fit.
Look and see if you can get 0.010" oversize if that's all your axle needs to clean up, saving the 0.020" oversize for more extreme wear or the second time around in another 60 years.
1952 Chevrolet 3800 pickup
---All pictures---
Aaron #1210471 03/27/2017 4:22 PM
Fox Offline
Aaron,
Yes that's how it starts, and soon you've touched every single nut and bolt in your truck! "Well, I've come this far. What's a little deeper going to hurt?"
It hurts nothing except the wallet!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox #1210486 03/27/2017 5:35 PM
Ah the Siren's Song "well while I've got this apart I might as well fix..."
That's why I have to wear ear plugs in the shop
Chuck
Grigg #1212609 04/11/2017 5:27 AM
Unfortunately I could not find .010" oversize but my machinist seemed to think the .010" would not have been enough anyway. I am finding this rig was very well used before my aunt and uncle got a hold of it (having been off the road since the 70's hasn't helped)
"While I'm at it, I might as well..." are a gear head's famous last words.
Aaron V.
Aaron #1212701 04/11/2017 10:49 PM
From my experience, when you get to the end and have it on the road, it is a pretty impressive machine. I really enjoy driving mine.
I am very much looking forward to that day!
Aaron V.
Moderated by  Dusty53
