0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | Several years ago I changed the much needed steering gearbox oil on my 1950 Chevy. The only oil readily available was SAE 90 synthetic which I used to fill up the box. I wasn't long after the gearbox would start slowly leaking to the point of emptying out withing several weeks on the pitman arm side. I assume it was to the synthetic brand of oil.
What I've read since then is there's a so call packing on that side of the box is it some kind of rope packing or a seal? Can it be replaced without removing the entire gear box?
Is this a common problem?
Could I use a good bearing grease instead of oil for the gearbox?
DR | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The closest grade self-levelling grease is a farm implement "corn head" (0 grade) grease, as sold by John Deere.
00 grease is the correct specification.
90 wt oil is too thin. Any weight oil is too thin.
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | You need a new seal, the packing material is the same thing. https://www.napaonline.com/en/p/NOS11055You can change this in the truck if you are careful. Buy two seals and take one back if you don't need it or get lucky and the first one goes right in. They are really thin and bend easy. You likely have worn bushings, have a helper turn the wheel back and forth while you watch the pitman arm. If there is side to side movement before twisting movement, the bushings are worn. This will cause any type of seal to leak over time. Get some Corn Head grease from John deere, it will not leak out and it's cheap. Most any dealer with large equipment will have it. The lawn and garden dealers maybe able to order it in or you can purchase online. One tube is enough for one gear box. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Another option for the right grease is Stens transmission grease. For lawnmowers... Available at your local mower shop.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Stens 00 grade 770-123 would match original spec for steering gear. https://www.stens.com/770-123-00-grease | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | DJ,
When I restored my '36 Chevy PU in the 1970s I machined the steering box to accept a very narrow seal for the Pitman shaft. Now 40+ years later it's still containing the 90W gear oil without leaking even a drop. So that's an option in addition to Corn Head Grease.
Ray
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | CV joint grease is something to think about too. Basically the same as corn head grease, you can get it at pretty much any parts store. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What is is NLGI rating of the CV joint grease that you use? Is it self leveling? | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Joe H, Is the NAPA seal you linked for a non-power steering gear? Also I believe that CV joint grease is NGLI 1.
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Many are 1 to 1.5 (non self-leveling) | | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | The number is correct, 11055. It fits most all GM manual steering boxes. Not sure why they call out for power steering.
Joe | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Anybody used Stens 00? I'm about ready to rebuild my steering box..
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
