| | | Forums66 Topics128,174 Posts1,057,114 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 21 New Guy | | New Guy Joined: Mar 2016 Posts: 21 | I noticed the inner panels are riveted to the fenders,do you guys separate these and are the rivets available or do you bolt them back together. Also are the inner panels painted gloss black or semi gloss? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Most vendors have smooth head bolts to replace rivets with for stock look. Semi gloss is more factory.
Another trick I did was to put a black rubber door edge guard along top edge of the inner fender to avoid chips, been on there many years.
