| | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | SO, one of my guys had 12,000 pounds on the back of my 46 2-ton on Friday. He pulls in to grab a drink and comes out to the steering wheel not working. He called and told me tat it didn't feel connected...
I sent two trucks and a forklift to unload the truck. When the truck got back to the shop, I looked at the top of the steering box and the shaft is heard off right at the top of the box.
I took a couple of other boxes apart that I had loose and it appears that the worm portion of the shaft was machined and hardened and then friction welded to the upper part of the shaft.
Has anyone ever had this happen to them? It couldn't have happen at a better time and I have to believe that someone was watching over him.
I am going to have the two I have apart magna fluxed before I put one good box together. Hopefully they come back ok! | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | That's a scary visual image! At even a few MPH, that could have turned deadly in a hurry! Jerry
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Well...
I disassembled to boxes that I had and had both shafts magna fluxed. Both came back good. I took the best of both boxes to make one good one. Now I have a little paintwork to do on the new tube that covers the shaft, but should be putting this back in this week.
| | | | | Joined: Feb 2007 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 112 | Was a problem with the old style boxes back in the day. The box and tube are mounted to the frame. The other end of the tube was mounted to the lower dash. Over time the cab would shift causing an out of line Condition stressing the shaft as it was rotated eventually cracking it.
That's why they went to a Rag joint or U joint. Tom | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Late 1960's to mid-1970's Ford pickups wee notorious for tearing up rag joints due to the front cab mounts rusting away and the weight of the cab being carried on the steering column. I've seen several of them with the cabs jacked up and 2X4's between the cab floor and the frame rails. Jerry
