3 members (klhansen, 6inarow, Oswald), 73 guests, and 1 robot.
Topics128,035
Posts1,055,549
Members48,425
Finally got around to investigating if the engine and head numbers match or even if I could find some information on them.
This is a Canadian built model 1434, Ser # 0143416066
Engine casting code X384619 matches the id plate on the door post.
Block # 3835327
The head casting located between number 1 and 2 valve springs under the cover shows 3835517 with GM above it and 2 below.( the head number is the only one I could confirm)
Checked on every site and link on here and then some and can find no definitive confirmation that this is a numbers matching engine.
Is it possible because it was never originally registered that it just disappeared from any database?
First drive after 3 years should be within a couple of weeks.
I'm also having it appraised later this month and would like to have something to show the fellow doing it!
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
USA 216 engines (Canadian codes might be different):
head 3835517 = 1950-1953
block 3835327 = no info (could it be 3835527?)
http://www.mapleleafup.net/forums/showthread.php?t=4482
This is from the Canadian casting Number File:
1950 CHEVROLET VAN ¾ TON ARTISTS STUDIO REYNOLDS-ALBERTA MUSEUM
MODEL 1467
0146710022
ENGINE # CR189,786 BLOCK CAST 3835327 HEAD 839401 IN NZ
THIS IS A LIGHT COMMERCIAL TRUCK ENGINE
01XXXXXXXX
I hope that helps. I have the file as a word file if you would like a copy.
1951 1 Ton Completed
Thanks guys really appreciate the help. I will be attending the Reynolds Museum in June for the History road exhibit and will see what they may have for information.
Kinda a follow up question on the valve cover. If I should repost under a new topic I will, there are slots that are open on the top are these for additional venting or to provide the intake of air to aid in blowby or both?
https://goo.gl/photos/spZbXT9Dd5hHovnT7
https://goo.gl/photos/xM57i8w3uz1hLozm9
The tube that comes out of the side of the block and curves below the motor creates a partial vacuum inside the crankcase when you drive down the road. The fresh makeup air comes from those slots that you mentioned.
Thanks makeup gas/air is a term I have used a lot in my line of work as a oil and gas consultant, I just wasn't sure if the slots were used to aid in the exhaust of blow by.
If there's enough blowby to get much vapor out of the top vents, the piston rings are worn out. Below 30 MPH there's not enough airflow past the end of the road draft tube to create a vacuum in the crankcase. A slight amount of vapor coming out of the valve cover slots is normal at idle and low road speeds, but if there's a noticeable amount of blush smoke puffing out of the top or bottom, it's engine rebuild time.
Condensation in the form of steam also exits the slots when not underway.
What is the story about this engine? How original is it?
Thats the million dollar question?
As far as I can tell or find while cleaning it up everything is original on the truck, It does have a rebuild tag on the carb but no indication of work being done on the engine. When I had the inspection done on it to register the mechanic said they were original plugs, points and wires. The brake shoes are all original with very minimal wear on the drums.
Does it still have the Thrift Master script on the valve cover?
Nothing on the valve cover other than mixed Saskatchewan dirt and oil residue!
See original post for engine and head casting numbers.
