2 members (jmoore, Cletus1950), 75 guests, and 2 robots.
Topics128,151
Posts1,057,007
Members48,460
#1211690 04/05/2017 4:47 AM
' Offline
I have a GM tilt wheel in my '53. Hired someone to wire it and he's gone in the wind! Anyway my turn signals only work when lights are off. When I turn lights on, turn signals just light up, no blinking. What's up electrical gurus?
Q
Q Offline
At first read I'd say the' gone in the wind' wiring guy screwed up! Now, unfortunately you will have to find someone to do it right. Not being able to physically look at,it will be impossible to tell you what's wrong. Being that it is a newer column in your truck there are to many variables to consider. Someone on here many have a wiring diagram drawn up from their project, that would help. Good luck!
They may actually be blinking, but the wattage of the running light filaments may be overpowering the turn signal filaments, making them indiscernible.
Another possibility is that the whizzing-in-wind guy put both tail light wire and blinker wire to the same filament.
Take off the lens cover, pull the bulbs, and use an ice pick-style test light to check each contact as an assistant turns on the lights and blinkers for you.
Carl
' Offline
Thanks.
' Offline
Thanks, Carl
' Offline
Thanks, Carl. All are LEDs. Would that make a difference? I'll try anything at this point.
Chuck
' Offline
Thanks, buddy.
LEDs are out of my league. Good luck to you though.
dbs Offline
juice going to the wrong filaments. switch the wires on them.
I had same issue. I agree with Dbs. You Will also need no load flashers to make them blink. I had 2 issues as a first time wired.
1. The ground is actually the bolt holding the body in place.
2. The second was that I had wires backwards.
This does not include the issues I had due to wire harness didn't work with my blinker switch.
Chris
Your fix may be as simple as changing the flasher relay. Most LED bulbs don't have enough resistance to make a standard old school flasher work. If everything else is the way it should be, changing to an electronic flasher may solve the problem.
38 Chevy 1/2 ton being resto-moded
65 AC Cobra replica
USAF vet
'53 Truck Chuck,
Is your electrical system the original 6v positive ground, or have you converted to 12v negative ground?
