0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 31 | I put a donor dash in my 48 panel. But I don't know what year it was 47-53. Now I need a glove box and they are different from 49 to 50. Can anyone tell me the difference. thanks | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Do you need the liner (cardboard) or the door?
| | | | | Joined: Mar 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 31 | The liner I think that is the only thing different. In the catalog they go 47-49 or 50-53. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Beg to differ! My 1949 3100 is a late '49 and had the metal band around the glove box along with the rubber windlace that slides into the channel around the doors.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Ok fixit, change it to oddball late '49's, feel better? | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The assembly is different also. On the earlier style (like the late 49 COE) You push the liner in through the opening and stop when it passes the hinge. Then put the metal band in. The screws go through the the band and cardboard (holes should line up) and screw into the flange of the dash. On the newer (51 COE) You push the liner all the way through (or bring it up from the back)and then fit it outside the flanges. The washer head screws drop through the holes in metal and through the holes in the cardboard and into individual sheetmetal nuts.
| | | | | Joined: Mar 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 31 | Do they take the same number of screws. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | NO. The metal band is countersunk for flat head screws. The later one uses washer head or truss head. | | | | | Joined: Mar 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 31 | Would you know how many screws goes in each one. My dash was strip when I got it. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Count the holes in the mounting flanges on the dash. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Wrote my late '49 off as a typical GM anomaly. Use what was left over on the assembly line and then move on to the new parts for the next year. All in the spirit of saving money? Early...late....don't think it really made that much of a difference. The assembly line used what they had in the bins and get them down the line. Just makes it tough when you are trying to restore a truck to the correct year. Cover one eye and try again.
Tim
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Maybe a quick way to which dash you have is to look at the flanges where the screws hold the cardboard insert in. Early holes are small and should show some signs of a sheetmetal screw being in them. The later ones have clearance holes because the screws drop through. Maybe even a mark from the screw heads. | | | | | Joined: Mar 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 31 | Thanks that is a great idea on the size of holes. I sand blasted and installed it and then painted it because I thought all the 47-53 dashes was the same. WRONG Thanks for the help. Steve Just went and looked holes are big and clean no thread marks or pulled metal from screws so I will order one for 50-53. Thanks again everyone.
| | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | Oh oh! By reading this thread, I learned that I'm missing still another part---thr glove box ring on my '47 3100. I hope it isn't as scarce as the under bed spare tire carrier-----they want my fist born male child for that one! Are these metal bands ez to find? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | In a word no, if someone has one here Swap Meet is your best bet, I have rarely seen one on eBay because I don't think people pull them as a rule on part outs, if you didn't know it was there you would miss it. | | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | Hehe......Brad you are 100% right. Never knew an animal like that existed! Who da thunk there ever was one? Doesn't look like there ever was one there. Can't miss what you can't see........ | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 |
