7 members (60steve, J Lucas, klhansen, greenie-reddy, NJC, TooMany2count, Lightholder's Dad),
130
Mod | | | Forums66 Topics128,277 Posts1,058,451 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | i have a 1962 235 hydraulic lifter engine that i bought last year from a guy who pulled it out of his 1958 Chevy car. i am planning on running it on a test stand. it came with a 12 volt generator and starter. it also has a Delco Remy coil. i dont know if there might have been a firewall mounted coil resistor on the guys car or if the coil has an internal resistor. i plan on running this engine on 12 volts, and i don't want to burn up the points. how can i tell whether or not to run a resistor to the coil? thanks | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | If it's got an original equipment Delco coil you need a resistor. With the engine running you need to see around 10.5 volts at the coil + terminal when the charging system voltage is 14+. If you're running on a 12V battery without the charging system in operation the voltage at the coil needs to be around 9V. Jerry
| | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | I plan on test running it without the charging system hooked up. Generator in place and spinning, but no wires running from it. Any recommendations on what or where for a resistor? Thanks | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Ebay has dozens of them. I just bought three to wire in parallel to make a voltage regulator setting resistor, for about $4.00 apiece. Jerry
| | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | Thanks Jerry. I stopped by my FLAPS and picked one up on my way home from work and got my engine running. | | |
