6 members (Nick in Manitou, Phak1, Otto Skorzeny, Hush, MickeyP, 59 fleet), 66 guests, and 2 robots.
Topics128,188
Posts1,057,331
Members48,469
#1211918 04/06/2017 7:20 PM
i have a 1962 235 hydraulic lifter engine that i bought last year from a guy who pulled it out of his 1958 Chevy car. i am planning on running it on a test stand. it came with a 12 volt generator and starter. it also has a Delco Remy coil. i dont know if there might have been a firewall mounted coil resistor on the guys car or if the coil has an internal resistor. i plan on running this engine on 12 volts, and i don't want to burn up the points. how can i tell whether or not to run a resistor to the coil? thanks
If it's got an original equipment Delco coil you need a resistor. With the engine running you need to see around 10.5 volts at the coil + terminal when the charging system voltage is 14+. If you're running on a 12V battery without the charging system in operation the voltage at the coil needs to be around 9V.
I plan on test running it without the charging system hooked up. Generator in place and spinning, but no wires running from it. Any recommendations on what or where for a resistor? Thanks
Ebay has dozens of them. I just bought three to wire in parallel to make a voltage regulator setting resistor, for about $4.00 apiece.
Thanks Jerry. I stopped by my FLAPS and picked one up on my way home from work and got my engine running.
