| | | Forums66 Topics128,107 Posts1,056,221 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | Has anyone ever altered a one half ton spare tire side mount so it can be used as a three quarter or one ton mount? In the factory assem. manual, it just appears the mounting plate is turned upside down. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | One thing that you'll want to keep in mind is that the 3/4 ton has a larger bolt pattern on the wheel. The plate for the 3/4 ton is probably larger as well to accomodate this. You could make a new plate with the bolts set up for the larger bolt pattern, weld it on in place of the 1/2 ton plate.
Bill Burmeister | | |
