6 members (Hotrod Lincoln, 48ed56pam, Ponchogl, lumbersawyer, MickeyP, Bill Hanlon), 136 guests, and 2 robots.
Topics128,081
Posts1,056,073
Members48,434
#121188 07/12/2006 12:45 AM
Has anyone ever altered a one half ton spare tire side mount so it can be used as a three quarter or one ton mount? In the factory assem. manual, it just appears the mounting plate is turned upside down.
#121189 07/12/2006 2:14 AM
One thing that you'll want to keep in mind is that the 3/4 ton has a larger bolt pattern on the wheel. The plate for the 3/4 ton is probably larger as well to accomodate this. You could make a new plate with the bolts set up for the larger bolt pattern, weld it on in place of the 1/2 ton plate.
Bill Burmeister
