| | | Forums66 Topics128,203 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 21 New Guy | | New Guy Joined: Mar 2016 Posts: 21 | Anybody out there have photos of clutch and brake pedal return spring mounting for a 46 half ton ? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2016 Posts: 21 New Guy | | New Guy Joined: Mar 2016 Posts: 21 | The manual is lousy 80%car 20% truck, the advanced design manual is much better,darn it
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Your right. Trying to figure it out is difficult. I have some photos in photo bucket. One thing to note is one of the springs requires an extension wire. I don't recall which one. | | | | | Joined: Mar 2016 Posts: 21 New Guy | | New Guy Joined: Mar 2016 Posts: 21 | I think the extension wire goes around the brake clevis bolt ,the spring hooks to it but there is a bracket that supports the splash pan ,it has a loose cotter pin thing that looks like it anchors a spring and there are holes in the bracket as well as a mystery 3" long by 1" flat stock bracket with quarter inch 90's ar each end that may bolt to the other bracket, the clutch spring anchors somewhere on that bracket , maybe,could be,I think,help? | | | | | Joined: Mar 2016 Posts: 21 New Guy | | New Guy Joined: Mar 2016 Posts: 21 | Gene, I just found a couple of photos of your beautiful truck that may help me out with my pedal return spring issue, thanks so much, Jim Brown | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | No problem. I would shoot some more photos for you but I'm in MI and my truck is in WA. | | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | Jcb3 Check your private messages. 46Sparky | | |
