0 members (), 70 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
Anybody out there have photos of clutch and brake pedal return spring mounting for a 46 half ton ?
Jcb3,
I do not know, but, have you looked in the Shop Manual?
The manual is lousy 80%car 20% truck, the advanced design manual is much better,darn it
Your right. Trying to figure it out is difficult. I have some photos in photo bucket. One thing to note is one of the springs requires an extension wire. I don't recall which one.
I think the extension wire goes around the brake clevis bolt ,the spring hooks to it but there is a bracket that supports the splash pan ,it has a loose cotter pin thing that looks like it anchors a spring and there are holes in the bracket as well as a mystery 3" long by 1" flat stock bracket with quarter inch 90's ar each end that may bolt to the other bracket, the clutch spring anchors somewhere on that bracket , maybe,could be,I think,help?
Gene, I just found a couple of photos of your beautiful truck that may help me out with my pedal return spring issue, thanks so much, Jim Brown
No problem. I would shoot some more photos for you but I'm in MI and my truck is in WA.
Jcb3
Check your private messages.
46Sparky
