3 members (55shaker, JW51, Gdads51), 147 guests, and 1 robot.
Topics128,070
Posts1,055,900
Members48,429
Hi all,
I am currently rewiring my 1949 3800 with a Speedway 12v 22 circuit harness and want to go with a more modern ignition switch with the start on the ignition instead of the old foot starter switch. If possible i would like to keep the look of the traditional ignition. is there such a critter out there? What have others used?
EDIT: I am using a 283 V8
Bryan
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
Use a mid-1950's Chevy passenger car ignition switch. It's not an exact match, but very few people will notice the difference.
Thank You Jerry, always bailing me out.. smile
Sir Searchalot
Sir Searchalot
Its going to be a challenge to get the 55-59 switch to fit in a '48 dash. They attach in very different manners.
The '47-'53 switches are held in place on a bracket behind the dash by 2 bolts which go through two long ears cast into the switch. The switch itself does not even contact the dash.
The '55-59 appears to have a threaded bezel which holds the switch to the hole in the dash.
I'm sure it can be done, but the challenge will be to make it pretty (albeit not stock in appearance).
Carl
Sir Searchalot
Sir Searchalot
I guess you can use the stock 49 switch and a "hidden" momentary push button switch under dash for the solenoid.
There would be ways to use the foot stomp and a switch to make it "original'ish", Maybe This
Riding in the Passing Lane
You can't use a foot stomp starter with a V-8 in the normal way. You can fake it with a starter button under the floor.
1972 Chevy c10 Cheyenne Super
