Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 112 guests, and 7 robots.
Topics128,281
Posts1,058,470
Members48,490
I am getting an odd intermittent vibration in my 1948 GMC 3/4 ton. It has the SM 420 trans. There is a straight shaft that is hooked up to the trans then that is connected to the driveshaft. Is there a bearing somewhere in there that could be going bad? Any help/advice would be appreciated.
Thanks.
Not sure about GMC but Chevy has a enclosed torque tube that connects the trans to the differential. At the trans end there is a u joint inside a ball shaped housing which may be causing the vibration.
Ed
I am thinking it is the U joint @ the transmission end. I am going to take it apart this evening and take a look.
Thanks for the info. I will post and let you know what I find
Crusing in the Passing Lane
One good way to evaluate U-joints, park on level ground, low gear, key in your pocket, get under truck and rock truck back and forth, easy to find sloppy U-joint that way.
Ed
