1 members (baldeagle), 79 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#1211444 04/03/2017 5:43 PM
A friend who has restored a few trucks in his time suggested these for my 53 to control handling better on our rural roads. I am going to install a sway bar at some point as well. It is my understanding that both serve different purposes. I would like to hear both pro and con on this subject. Thanks, Steve
53Movinon #1211452 04/03/2017 6:32 PM
Traction bars are made to help control axle wrap on acceleration. They can also help with wheel hop. I see no useful purpose for traction bars on a stock 1/2 ton pickup. JMO👎🏻
Well, that could be the reason I have never seen a post on the subject. Thanks for your reply and I hope some of you other bolters may have an opinon. Steve
53Movinon #1211482 04/03/2017 10:44 PM
On a stock rear end setup, the torque tube IS a traction bar. The front end of the driveshaft (torque tube) is anchored vertically at the transmission connection so it resists the torque when power is applied. Add-on traction bars would be redundant. If you've changed out the rear end to one with an open driveshaft (u-joints both at tranny and rear axle), then the springs are what resist axle wrap. If it's a higher powered engine than stock, you might consider traction bars. Otherwise, not worth the effort and cost, IMO.
Sway bars flexibly tie right and left side of the axle to the frame to reduce sway (leaning sideways on turns). Again, probably not neccessary.
klhansen #1211511 04/04/2017 1:51 AM
Thanks for the good information. I don't want to be accused of redundancy LOL. I still plan to use a sway bar however. Several guys believe it has made a big difference. Steve
53Movinon #1211531 04/04/2017 2:59 AM
Crusing in the Passing Lane
One can stagger the shocks if exact originality does not need to be kept. One shock in front of the axle and one in the rear of the axle. Modern trucks do this.
Ed
53Movinon #1211716 04/05/2017 11:45 AM
ODSS Lawman
ODSS Lawman
Sway at is the way to go. It will make a difference in windy roads.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
53Movinon #1211718 04/05/2017 11:59 AM
sway bars are the single most bestest investment I have made for my truck. I highly recommend them.
53Movinon #1211767 04/05/2017 6:24 PM
I have a front sway bar on the '48 Suburban and it does seem to help.
53Movinon #1211810 04/06/2017 12:25 AM
A "Ride Stabilizer" was standard equipment on 47-55st panel body trucks.
It can be easily mounted on pickups. GMC and Chevrolet had different style stabilizers.
They provide a noticeable improvement when used on pickups.
53Movinon #1212642 04/11/2017 3:05 PM
As far as sway bars are concerned - "noticeable improvement" is almost an understatement. I disagree with klhansen, If your truck is driven a lot, or daily, a sway bar becomes necessary.
