| | | Forums66 Topics128,091 Posts1,056,392 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 27 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 27 | Howdy - been following for a couple years looking for wheel solutions, but never posted. 1950 6400 RH-5 wheels with severely dry rotted tires (still hold air though) just used for slow speed around the place.
Was getting discouraged about finding replacement wheels after reading everything on here and elsewhere. Came across something today that I'm hopeful will work. They're a complete set of split/ lock ring off what I'm guessing to be a 1940s truck. Tires on em are 7.5 x 20 hub piloted 4.75 x 10 hole 7.25. Stud holes look a little small and may need expanded slightly.
The couple unmounted look dang good inside - we'll' see what I find on the others.
Haven't check the backspace/offset yet but looks very close.
Has anyone on here used the older rims on their outfit? Got pictures but don't think I can post yet. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | The only issue I could see is that the older rims would be to narrow for later and larger truck applications. | | | | | Joined: Mar 2017 Posts: 27 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 27 | Thanks for the input. Are you thinking they'd be too narrow functionally or from a looks standpoint? The truck has 8.25 x20's on now and the rh-5's are 6.5 inches wide. The older rims are 6.0 inches wide and I was hoping they would support 8 or 8.25 tires. Also, I was wrong about the studs, they are the same size. Thanks for any feedback, Mark | | |
