5 members (Charles in CA, mick53, Gray_Ghost, BC59, klhansen), 168 guests, and 1 robot.
Topics128,113
Posts1,056,277
Members48,439
#1211090 04/01/2017 2:13 AM
Howdy - been following for a couple years looking for wheel solutions, but never posted. 1950 6400 RH-5 wheels with severely dry rotted tires (still hold air though) just used for slow speed around the place.
Was getting discouraged about finding replacement wheels after reading everything on here and elsewhere. Came across something today that I'm hopeful will work. They're a complete set of split/ lock ring off what I'm guessing to be a 1940s truck. Tires on em are 7.5 x 20 hub piloted 4.75 x 10 hole 7.25. Stud holes look a little small and may need expanded slightly.
The couple unmounted look dang good inside - we'll' see what I find on the others.
Haven't check the backspace/offset yet but looks very close.
Has anyone on here used the older rims on their outfit? Got pictures but don't think I can post yet.
The only issue I could see is that the older rims would be to narrow for later and larger truck applications.
Lots more pictures
Thanks for the input. Are you thinking they'd be too narrow functionally or from a looks standpoint? The truck has 8.25 x20's on now and the rh-5's are 6.5 inches wide. The older rims are 6.0 inches wide and I was hoping they would support 8 or 8.25 tires. Also, I was wrong about the studs, they are the same size. Thanks for any feedback, Mark
