6 members (Otto Skorzeny, King Kielbasa, Gdads51, Jay R, JoergK., Robert Crandall), 81 guests, and 6 robots.
Topics128,181
Posts1,057,152
Members48,464
I have a 54' 3100 step side and removed my current license plate that was mounted towards the left side under the tail gate. I bought original 51' larger California license plates and bought a rear license plate mounting bracket that had a light on it. I'm just wondering where it actually goes or how to mount it? I do not have a rear bumper with the dip in the center. I also have 39' Ford frenched in tail lights. Any ideas folks. Thank you in advance.
Where it goes is up to you since it is not stock.
I had same problem with my '46, used a '49 Chev passenger car's front license plate guard and made it fit my rear bumper. This item is available from vendors like Chevs of 40s etc and show up at swap meets.
I'll try to pm a photo for you.
Best of luck
1946 1/2-Ton Chevy
Mariano,
Did you buy a 1951 truck rear license plate bracket/holder?
"39' Ford frenched in tail lights" - can you post a link to a photo?
I bought a 54' rear license plate holder that comes with a light. I will try and post a pic, not so savvy with a computer and posting as some folks.
I know for a 54 3100 the license plate bracket is suppose to mount in the middle. The bumper of a 54 should have about a 20 inch wide depression along the top of the bumper in the middle that is there to allow you to see the license plate.
Wait, as I was typing this I just realized my 54 does not have the correct bumper. I don't have the depression. Now I am depressed.
54 rear license plate bracket with light
Dave from Northern Kentucky
My 54 3100
I have the same rear bumper as you do, no depression. I'll have to double check because since the truck is modified, I don't think I have as much room between the bumper and bottom of the tailgate. I bought the front splash apron that fills the front bumper and grille area and I couldn't fit it in there. Not sure if he modified the depth of the bumper or not. I really need to post pics. I might just have to drill a new hole under the tail gate. There's 2 already there for the current size license plate CA uses. I bought these 51' plates and they're cost me a pretty penny since they were clear to register and are in awesome original shape.
Q
Q Offline
When I got my 54 it had the license plate on a non oem step style bumper. That bumper is gone and I currently have a license plate bracket that attaches to the back of the left tail light. I got that from chevs of the 40's.it is a factory option as far as I can tell,as I have seen them on other trucks..could be another option for you.
Thank you for the idea and I have seen that as well. The problem with that style holder is that I have 39' Ford tail lights frenched into the rear fenders as I noted in my initial post.
As posted above, can you post a photo of what you have to attach to, and what you have that needs to be attached?
I mounted it under the tailgate to the left side. Used a preexisting hole and drilled another. I have a license plate frame with the current stickers so I had to get longer screws. It looks pretty good. Thanks all for your help.
