| | | Forums66 Topics128,165 Posts1,056,989 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 3 New Guy | | New Guy Joined: Mar 2017 Posts: 3 | Hi Im new to stovebolt, does anyone know the board width for a 37 truck bed | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | If you don't get an answer here Mar-K has dimensions on their web site.ðŸ‘ðŸ»
| | | | | Joined: Mar 2017 Posts: 3 New Guy | | New Guy Joined: Mar 2017 Posts: 3 | | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | I can check my '36 if you think they are the same. Please let me know. Is your '37 original or a street rod? I ask because I have a NOS Sorensen carburetor kit for a '37 Chevy.
Ray
| | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | I measured the boards on my '37 Chevy 1/2 ton.
Two, one on each end, are: 7 3/4" wide Four are: 7 7/16" wide
Length for all 6 boards is: 86"
Edit adddition--I do not know the thickness for a '37. But, if IF, it is the same as for a '46: it is 13/16".
| | | | | Joined: Feb 2010 Posts: 86 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 86 | i seen chevys of the 40's has the wood bed kits and hardware | | | | | Joined: Mar 2017 Posts: 3 New Guy | | New Guy Joined: Mar 2017 Posts: 3 | thanks for board sizes ,thetruck is a hot rod | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I measured the boards on my '37 Chevy 1/2 ton.
Edit adddition--I do not know the thickness for a '37. But, if IF, it is the same as for a '46: it is 13/16". Standard wood thickness: Soft woods are 3/4" thick. Hard woods are 13/16" thick. Jeffrey | | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | The yellow pine bed remnants removed from an unmolested parts truck '46 I had access to measure 13/16" in thickness.
In '37 oak would have been used for truck bed material. Do not know for certain the thickness used back then. | | |
