4 members (GRNHydra, Rusty Heaps, Opelika Tom, greenie-reddy), 124 guests, and 3 robots.
Topics128,164
Posts1,056,967
Members48,458
#1210765 03/29/2017 2:59 PM
Hi Im new to stovebolt, does anyone know the board width for a 37 truck bed
If you don't get an answer here Mar-K has dimensions on their web site.👍🏻
thank you
Y
yar Offline
Y Offline
I can check my '36 if you think they are the same. Please let me know. Is your '37 original or a street rod? I ask because I have a NOS Sorensen carburetor kit for a '37 Chevy.
Ray
wnswt64 #1210954 03/30/2017 11:46 PM
I measured the boards on my '37 Chevy 1/2 ton.
Two, one on each end, are: 7 3/4" wide
Four are: 7 7/16" wide
Length for all 6 boards is: 86"
Edit adddition--I do not know the thickness for a '37. But, if IF, it is the same as for a '46: it is 13/16".
i seen chevys of the 40's has the wood bed kits and hardware
thanks for board sizes ,thetruck is a hot rod
Standard wood thickness:
Soft woods are 3/4" thick.
Hard woods are 13/16" thick.
Jeffrey
The yellow pine bed remnants removed from an unmolested parts truck '46 I had access to measure 13/16" in thickness.
In '37 oak would have been used for truck bed material. Do not know for certain the thickness used back then.
Moderated by  ndkid275, Phak1
