1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#1210309 03/26/2017 4:41 AM
A number of years ago I made the change from Rochester to a Carter YF 2101S on my 60 235 (in my 53). Its a great carb, but the auto choke has always been a bit temperamental, great when its in proper adjustment, and a pain to adjust when its not.
so my question, is anyone aware of a manual choke conversion kit for this carb? Alternatively, if anyone knows the appropriate manual choke YF model, I'm all ears.
thanks guys,
-Chris
1953 Chevrolet 3100
The 2100s is a manual choke version. I'd like to find one too.
1951 3100
JW51 #1210312 03/26/2017 4:48 AM
ahh, good to know, thank you.
Despite the auto choke, the YF is still much better than the Rochesters I've run. I'm not saying Rochesters cant work well, just that I have three of them on the shelf collecting dust. smile
1953 Chevrolet 3100
Carburetion specialist
Chris - the automatic choke MAYBE should need adjustment every 20 years or so, not more often, and it takes less than 2 minutes to adjust! Call me! 573-392-7378 (9-4 Mon-Tues central time).
JW - the 2100s are readily available, just significantly more money than the Rochester.
Jon
The Carburetor Shop
Yeah.
I actually have a nice rebuildable 2101s, but I'd prefer to keep the manual choke, so I keep looking for a 2100. Haven't found one at the right price yet.
1951 3100
If the 2100s is readily available I must have been looking in the wrong places. I did eventually locate one after looking for a while. Rebuilt it with a kit from Carbking. It seems to be working perfectly but so was the Rochester I replaced. I guess I had a good one (I used the best parts from 3 to rebuild it originally). So far I can't detect any advantage to the Carter. I hope to see better fuel mileage but keep forgetting to note the milage at fillups.
You can find the Carter YF 2100S on Ebay or you may get lucky at a swap meet. Most of the ones I've seen usually need the throttle body rebushed.
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
