| | | Forums66 Topics128,047 Posts1,055,622 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | So I'm 7 years deep into a 58 Apache restoration and I've managed to get around to starting the rebuilt 235.
Fuel is pouring out the butterfly shaft bushing, and quite honestly the carb looks like complete hell.
I need a new carb for this old girl. The old Rochester has put in many decades of service, and its time to move on.
I see Carter makes a carb with an ever-appealing auto choke feature.
What do you guys think? Is this a wise move? what do you kings of carburation recommend?
Thanks fellas! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What model Carter?
What size engine was it used on?
| | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | Engine is a 58 235 bored 40 over.
Don't know which model Carter, what do you think would work? Ive seen a few listed that work on the 235 but I don't have a particular in mind. | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | The Carter YF 2100S was manufactured for the 55-59 235's. It was specifically made by Carter as an aftermarket replacement for the stock Rochester B. It bolts right on and the linkage is an exact match. It is a manual choke. If you start to look for a Carter YF, be sure that you hunt specifically for a 2100S model. There are many different model YF's, and you'll want to find the one made for your '58 235.
Matt | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
