2 members (Peggy M, Hotrod Lincoln), 89 guests, and 2 robots.
Topics128,169
Posts1,057,043
Members48,458
#1208759 03/15/2017 9:32 PM
I'm trying to fix my amber cab lights on the roof of my '57 6100. They used to work and the switch isn't that old. I have the truck sold and would like to get them working again for the new buyer. I've looked for the fuse box but haven't found it as of yet. To those in the know, where is it located? Am I not looking far enough under the dash? Thanks in advance! JP
if you do have a fuse panel it should be on the foot board above the clutch pedal, looks like this, but one wasn't installed factory unless there was a number of electrical options, and I doubt clearance lights were factory in '57
7
7 Offline
My '57 5700 LCF has no fuse block. Cigar lighter, electric wipers, heater and gages are the only interior load.
Could be why I can't find one. Above the clutch pedal was the first place I looked. Thanks JP
The roof clearance lights should be tied into the taillight circuit, did someone accidently hook then to the running lights (they go off when the headlights are ON)?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The roof lights were put on a separate light switch. They used to work. Since all 3 are out, I thought there was a fuse out. It's either a bad switch or the wire to the switch is unhooked. (Doubtful that all 3 bulbs would burn out at the same time). Thanks JP
That's easy enough to test with a simple test light...check for voltage on both terminals of the on/off switch and see if you have power. If no power, start tracing the hot wire back to the source and see what you find.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
My buyer didn't care about the roof lights and took the truck like it was. Thanks for the help. JP
