4 members (Charles in CA, Shade Baby, Hotrod Lincoln, 46 Texaco), 119 guests, and 3 robots.
Topics128,162
Posts1,056,913
Members48,458
My truck came with the optional elec. motor which has failed. I can't find a replacement under $500 on eBay. None of the vendors I've searched seem to have them.
The solution is to buy one of the vacuum conversion motors, which require different arms, so I'd have to buy those, too.
I'm prepping the truck to sell (BaT has accepted it) and want to list it with "wiper motor inop, replacement supplied", but I'm unclear if that conversion motor takes the old cable switch or will use the elec. switch of the motor/switch set up I've got now. That is, do I need to get a conversion motor, the arms, AND a switch??
Anybody help with some info?
thanks!
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
V
VEW Offline
V Offline
There are places/people that will rebuild the motor. I have done business with The Wiperman, in WI (?) many years ago. You may find someone closer.
~ Victor
1957 3100 - moved on
V
VEW Offline
V Offline
Here's a place, but I have not done business with them.
Ficken Wiper Service
132 Calvert Ave
West Babylon, NY 11704
(631)587-3332 M-F 9-5 EST
~ Victor
Ficken doesn't do electric motors or sell parts
Rev, if you go to the repro electric vacuum replacement you'll need the different link arms from the original vacuum setup, but the new wiper motor should come with a switch [electrical, shown here], the cable switch is only used on a vacuum motor
Ebay, search 58 chevy wiper motor. There are a few on there today when I looked.
1959 3204 Basic Cab
There is a guy in CA that has original electric motors that are supposed to be in working condidition I've dealt with before. Let me find his email address and I'll PM it to you.
1959 3100 Apache Fleetside
PM sent
