7 members (John Dlugos, Bill Hanlon, klhansen, Gray_Ghost, Otto Skorzeny, Gdads51, 1 invisible), 178 guests, and 2 robots.
Topics128,101
Posts1,056,179
Members48,436
#1208607 03/14/2017 11:21 PM
Ok I guess you could consider this custom work, I just finished installing all new brake lines in my 52 3100, new dual master with booster under floor. My question is I haven't yet attached lines to new master cylinder, do I really need to remove it to bleed the master out? It sits fairly level as attached to frame and would it hurt the booster to use the pedal arm for bleeding purposes?
Thanks for your thoughts
Joe
There should be no problems with 'bench bleeding' it where it sits.
I didn't have any issues once everything was tightened!
