2 members (TPR57C, 1955 1 Series), 376 guests, and 4 robots.
Topics128,159
Posts1,057,033
Members48,460
Stovebolt Photo Moderator
Good morning fellow bolters. I secured a short shaft water pump from NAPA. I now need a shallow pulley. Can anyone offer a source for one? I spoke to a woman at Jim Carter's "sales" desk. For the first time I was truly underwhelmed with the discussion. Anyway........ideas welcome.
Yes - I know they are offered as a kit "pump and pulley" but I bought most of them are not dual outlet for using the 261 bypass t-stat housing.
Best - Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
Best - Joe [/quote]
I have a 261 I pulled from a 55.1 truck, has high mount pump, no bypass thermostat, only one heat hose nipple on pump. Not sure if the thermostat bypass system was used on early 261, perhaps other will.
BC
1960 C60 pasture art
Do you have a picture of what your looking for? My short shaft pump had the pulley on it.
1951 3100
I do not have a picture but I will look to get one. A friend has the setup on his 261. I should see him this weekend.
I imagine if you search the forums there are volumes written on the merits of the dual outlet pump and thermostat housing. Particularly when using with an 848 head. I've decided to use both. I bought a dual outlet water pump from Rock Auto but it does not come with a pulley, hence my journey to find one.
Back in the day we used a 292 Ford pulley.
Summit racing sells them.
I checked out Summit - they only have one that is 2-3/4" deep. I need one 2" deep. Probably the one everyone sells as a companion with the water pump. I just need a number I guess.
Patrick's Antique auto has a the short shaft pump, not sure if they will sell just the pulley?
1946 1/2-Ton Chevy
I read that a 292 Ford pulley will work. I checked my spare 292 Ford pulleys for you. They are 2 1/2" deep and have a different bolt pattern. Dave
H Online: Content
Try a MOPAR V8 pulley- - - -it looks right in pictures, but I don't have one handy to measure.
You can always turn the pulley 45 degrees and drill any bolt pattern you want if you can find one with the right offset. The center hole can also be drilled or machined to a bigger diameter or a bushing can be fitted to a too-big hole. I've even seen a good welder/machinist make a new center and weld it into a pulley when he needed something that was not available off the shelf.
