| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 443 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 443 | Good morning fellow bolters. I secured a short shaft water pump from NAPA. I now need a shallow pulley. Can anyone offer a source for one? I spoke to a woman at Jim Carter's "sales" desk. For the first time I was truly underwhelmed with the discussion. Anyway........ideas welcome.
Yes - I know they are offered as a kit "pump and pulley" but I bought most of them are not dual outlet for using the 261 bypass t-stat housing.
Best - Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | Yes - I know they are offered as a kit "pump and pulley" but I bought most of them are not dual outlet for using the 261 bypass t-stat housing.
Best - Joe [/quote]
I have a 261 I pulled from a 55.1 truck, has high mount pump, no bypass thermostat, only one heat hose nipple on pump. Not sure if the thermostat bypass system was used on early 261, perhaps other will.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Do you have a picture of what your looking for? My short shaft pump had the pulley on it.
1951 3100
| | | | | Joined: Nov 2012 Posts: 443 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 443 | I do not have a picture but I will look to get one. A friend has the setup on his 261. I should see him this weekend.
I imagine if you search the forums there are volumes written on the merits of the dual outlet pump and thermostat housing. Particularly when using with an 848 head. I've decided to use both. I bought a dual outlet water pump from Rock Auto but it does not come with a pulley, hence my journey to find one. 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Back in the day we used a 292 Ford pulley. | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Summit racing sells them.
| | | | | Joined: Nov 2012 Posts: 443 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 443 | I checked out Summit - they only have one that is 2-3/4" deep. I need one 2" deep. Probably the one everyone sells as a companion with the water pump. I just need a number I guess. 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Patrick's Antique auto has a the short shaft pump, not sure if they will sell just the pulley? | | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | I read that a 292 Ford pulley will work. I checked my spare 292 Ford pulleys for you. They are 2 1/2" deep and have a different bolt pattern. Dave | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | Try a MOPAR V8 pulley- - - -it looks right in pictures, but I don't have one handy to measure.
You can always turn the pulley 45 degrees and drill any bolt pattern you want if you can find one with the right offset. The center hole can also be drilled or machined to a bigger diameter or a bushing can be fitted to a too-big hole. I've even seen a good welder/machinist make a new center and weld it into a pulley when he needed something that was not available off the shelf. Jerry
