4 members (Charles in CA, Shade Baby, Hotrod Lincoln, 46 Texaco), 119 guests, and 3 robots.
Topics128,162
Posts1,056,913
Members48,458
Apprentice
Apprentice
I'm thinking of drilling out the rivets that hold the rear fender center brace in place and plug welding the brace to the fender. Has anyone ever done this successfully?
It seems that leaving the rivets could help promote rust, and based on what I have been going through with rust removal I don't want to create more problems down the road. Would welds hold up in this application?
Don't weld them. Welding it is not the way to go at all. You WILL see it down the road. If you were to do something like that, extend the inner lip up and bolt it to that like most other cars and trucks used.
I personally used bolts with rivit heads (you can make them, I got mine from an old Gym locker) and it works like a charm. Mine have not shown one speck of rust, and it was twenty five years ago I replace the rivits.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
I completely removed the rear braces, mainly for tire clearence. Then welded up the holes.
wilbur
50 chevy p/u on hotrodders.com
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
NOT a good idea
but it's your truck
Jim & Caroline
Apprentice
Apprentice
Well I do want to keep the braces, so I guess I'll have to keep the rivets too...
Thanks for the feedback!
Getting our truck painted next week. Painter said something about removing the rear fender braces. Said it would be easier for him to rub out etc., without those rivits. Told him I would think about it. Any suggestions?
Junior Member
Junior Member
I left the rear fender braces on my 52 chevy truck and it is getting painted right now and the painter has had no problems with the braces if that helps you any.
Smoke Em if You Got Em
RYAN
Z
Z Offline
Removed my rivets and welded, wanted the smooth look, its just my preference. Can see it here
http://community.webshots.com/user/zeker6
also added fuel door for my undermount tank, Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
Like I said, just polish the head on an oval head machine screw to look like a rivit and bolt it back together after buffing.
Brian
1948 Chevy Pickup
Junior Member
Junior Member
zeker thats is a really nice looking 51 you have.
ryan
RYAN
