3 members (Hotrod Lincoln, 2-Ton, 1 invisible),
63
Mod | | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Read an article a while back of upgrading the points dist. to solid state.,It said a late 70s GM dist. where coil is separate from dist. I believe it was from a 250,or 292 engine(I have a 235) Is this correct? Has anyone done this? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | It doesn't just fit. Put a pertronics ignition in, or look at Langdon's stovebolt engine co., He has one already modified and ready to drop in.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Dec 2002 Posts: 3,437 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,437 | I installed an aftermarket electronic type ignition into my stock distributor... no more points!!
| | | | | Joined: Aug 2011 Posts: 226 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 226 | I installed the Petronix and am still having advancing or not enough advancing occurring on full acceleration. Talked to Petronix as they thought I could have purchased one of three available for our trucks a couple of years ago. They thought if I had an old unit, it could be indexed wrong.
I have the correct unit for my 228 GMC, so I am still working on getting my advance back.
Any advice? | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | I am not the best mechanic,but I did not think it would just go in. Thanks for your insite. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I installed the Petronix and am still having advancing or not enough advancing occurring on full acceleration. Talked to Petronix as they thought I could have purchased one of three available for our trucks a couple of years ago. They thought if I had an old unit, it could be indexed wrong.
Any advice? Did you dig deeper into the distributor to determine the condition of the mechanical advance mechanism? There are springs, advance weights, and the pins which the weights ride on. Lots of places for wear to occur.
