6 members (Donf, Gray_Ghost, Peggy M, SWEET, mvigo, rfs56trk), 48 guests, and 3 robots.
Topics128,023
Posts1,055,367
Members48,420
#1207542 03/09/2017 12:32 AM
Read an article a while back of upgrading the points dist. to solid state.,It said a late 70s GM dist. where coil is separate from dist. I believe it was from a 250,or 292 engine(I have a 235) Is this correct? Has anyone done this?
It doesn't just fit. Put a pertronics ignition in, or look at Langdon's stovebolt engine co., He has one already modified and ready to drop in.
Tommy
59 apache 1/2t
261 short stepside
I installed an aftermarket electronic type ignition into my stock distributor... no more points!!
Another quality post.
Real Trucks Rattle
I installed the Petronix and am still having advancing or not enough advancing occurring on full acceleration. Talked to Petronix as they thought I could have purchased one of three available for our trucks a couple of years ago. They thought if I had an old unit, it could be indexed wrong.
I have the correct unit for my 228 GMC, so I am still working on getting my advance back.
Any advice?
I am not the best mechanic,but I did not think it would just go in. Thanks for your insite.
Any advice?
Did you dig deeper into the distributor to determine the condition of the mechanical advance mechanism? There are springs, advance weights, and the pins which the weights ride on. Lots of places for wear to occur.
