7 members (Gdads51, R&S 51 GMC, Otto Skorzeny, Hotrod Lincoln, Ponchogl, crenwelge, Gray_Ghost), 106 guests, and 0 robots.
Topics128,125
Posts1,056,341
Members48,440
I put new springs all the way around when I built the truck four years ago. Maybe 8,000 miles on it. When I was changing the oil last week I noticed the front springs were almost flat looking. All new shackles and bushings and hardware too. Anything that moved or twisted was replaced. The rubber bumper is only 3/4" to 1" from the bracket that wraps around the spring. The front shackle is forward over center. I got the springs from Keystone Spring Service in Pittsburg. $198.00 ea.
Do they seem a little low to anyone?
Thanks Sharon
That sounds a little low to me. Somewhere in the specs for the truck they should give a height for the truck unloaded. I think it would be a measurement to the frame.
1951 1 Ton Completed
I read your post and checked my '57 3/4 ton. It has about 1 1/2" clearance. Not sure how this would compare to a '54, but this gives you a reference point.
Matt
Thanks Maybellene. I'm going to call the spring shop and ask them some questions.
