| | | Forums66 Topics128,074 Posts1,055,911 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Good afternoon. My son just picked up a 235 and transmission. We need to put on a stand/cradle with wheels until we can get it put into the truck. I've seen the one in the tech area... http://www.stovebolt.com/techtips/engine_dolly.htmlI don't think this will work with the transmission attached. What are our options? I don't want anything with any chance of tipping over. With our luck, it will. Thanks! Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Should still work, worst case you take trans off only 4 bolts. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Just make it a little bit longer to hold the rear of the transmission.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3 speed of 4 speed transmission?
I'd risk trying a 3-speed in the cradle (if it fits), but no way risk trying a 4-speed. | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Don't see where it would be a problem with either 3 or 4 speed. I have my 235 sitting in one I built from the tech tip. The thing is stout, the weight of the engine itself should counter balance the transmission.
Joe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Balance is one of the important issues, as would be stability when moving over sills and up or down slopes.
Also, do not use low-rated wheels - probably no less than 500lb or 600lb load-rated wheels (each wheel) should be used?
An SM420 weighs around 150 lbs (without u-joint/housing).
A 216/235/261 stovebolt engine weighs around 600 lbs (no manifolds or peripherals). | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | It's a 4 bolt transmission. I think we'll just try to remove the transmission as suggested. I have a box of wheels from some old wheel dollies. I'm not sure of the load rating on those. Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Made the cart in the tech area then added a rear extension to accommodate the transmission. Seems to be working. We'll see if I hear a loud thud in the middle of the night. Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I just built one of these and it works great. Just be sure you go by the dimensions and it will fit like a glove. There is another post regarding wheel size which you should find helpful.I bought some that were too small before that was posted. Steve | | | | | Joined: Jan 2016 Posts: 5 New Guy | | New Guy Joined: Jan 2016 Posts: 5 | What are the specs for the trans cradle?
Can you post the link to the wheel size post, I can't seem to find it.
