4 members (Otto Skorzeny, Steelonsteel, klhansen, Bill Hanlon), 61 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
Good afternoon. My son just picked up a 235 and transmission. We need to put on a stand/cradle with wheels until we can get it put into the truck. I've seen the one in the tech area...
http://www.stovebolt.com/techtips/engine_dolly.html
I don't think this will work with the transmission attached. What are our options? I don't want anything with any chance of tipping over. With our luck, it will.
Thanks!
Ron and Ryan Hill
1952 Chevy 3100
Should still work, worst case you take trans off only 4 bolts.
1946 1/2-Ton Chevy
Just make it a little bit longer to hold the rear of the transmission.
Tommy
59 apache 1/2t
261 short stepside
3 speed of 4 speed transmission?
I'd risk trying a 3-speed in the cradle (if it fits), but no way risk trying a 4-speed.
Don't see where it would be a problem with either 3 or 4 speed. I have my 235 sitting in one I built from the tech tip. The thing is stout, the weight of the engine itself should counter balance the transmission.
Joe
Balance is one of the important issues, as would be stability when moving over sills and up or down slopes.
Also, do not use low-rated wheels - probably no less than 500lb or 600lb load-rated wheels (each wheel) should be used?
An SM420 weighs around 150 lbs (without u-joint/housing).
A 216/235/261 stovebolt engine weighs around 600 lbs (no manifolds or peripherals).
It's a 4 bolt transmission. I think we'll just try to remove the transmission as suggested. I have a box of wheels from some old wheel dollies. I'm not sure of the load rating on those.
Ron and Ryan Hill
1952 Chevy 3100
Made the cart in the tech area then added a rear extension to accommodate the transmission. Seems to be working. We'll see if I hear a loud thud in the middle of the night.
Ron and Ryan Hill
1952 Chevy 3100
I just built one of these and it works great. Just be sure you go by the dimensions and it will fit like a glove. There is another post regarding wheel size which you should find helpful.I bought some that were too small before that was posted. Steve
1 Offline
What are the specs for the trans cradle?
Can you post the link to the wheel size post, I can't seem to find it.
