8 members (Hotrod Lincoln, farmallb, Chip O, tclederman, Charles in CA, Otto Skorzeny, Stovebolt48, TooMany2count),
46
0
Mod | | | Forums66 Topics128,006 Posts1,055,272 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 55 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 55 | Factory assembly manual shows where seam sealer is to be applied in cab areas but couldn't see anything for rear of panel trucks. Are there areas of the panel that require seam sealer? I have seen on here that some are sealing the drip edge but wasn't so sure of that, didn't see anything in that area when stripping paint. Thanks | | | | | Joined: Mar 2017 Posts: 13 New Guy | | New Guy Joined: Mar 2017 Posts: 13 | I believe that there is sealer around the flange that bolts to the floor like under the wheel well flange and under the back piece also | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think that dbs is correct. | | | | | Joined: Mar 2007 Posts: 55 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 55 | Allrighty, areas around the fenders have some good sized gaps, the rest is pretty tight. See what I can do without making too big a mess.  Thanks | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | King, Not sure what brand seam sealer you are using. I really liked the 3M Fast and Firm before they went to a new formula. Some guys love the new stuff... I'm not one of them. We use either SEM or 3M 2 part seam sealer now. It does require the special gun to go with it, but it does go on much better. We use reducer to dip our finger in to spread the seam sealer. This helps the seam sealer not stick to your fingers. Put some in a small cup and dip your finger often to keep things from getting out of control.
We use reducer because it generally will not effect the primer or other paint like lacquer thinner would....
Good luck!
| | | | | Joined: Mar 2007 Posts: 55 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 55 | Appreciate the advice, haven't bought any seam sealer yet. Checking the web and prices are all over the place. Will have to see what my local guy has to offer, he has been pretty reasonable as of late. | | |
