6 members (Tom McGrath, 32Fordpuchoptop, Otto Skorzeny, Gdads51, Wickedbass, 1 invisible), 94 guests, and 2 robots.
Topics128,094
Posts1,056,051
Members48,433
#1202497 02/01/2017 2:30 PM
Has anyone installed a "modern" cable type spare tire holder under a 49-3100 pickup bed? If so I would appreciate pictures and make/model of holder
Doug
[email protected]
dougs #1202553 02/01/2017 10:48 PM
Haven't done it, but it's an intriguing idea. I'm wondering if you could find a unit that was shallow enough to work with the relatively narrow stock wheels, if that's what you're going for, since most later model cars and trucks have pretty large offset. Maybe a spare tire winch from a late model import would do the trick. You could fab a plate for mounting from the two U-channels that bolt to the frame for the stock spare tire holder.
If you do it, post up some pics.
dougs #1202555 02/01/2017 11:13 PM
Should be an easy install, with the cable unit from a modern pickup, great idea!!!
1946 1/2-Ton Chevy
dougs #1202584 02/02/2017 1:28 AM
We do this on every under bed spare. Remove everything but cross member at front of tire and add an additional one for rear of tire to rise flat up against. Prefer some of the Nissan pickup ones because it will take a 3/8 extension square end. The cable is long enough you can put the crossbar through the center hole with spare completely behind the truck and it will pull the tire under the truck and then up. Nice when in a muddy/dirty spot or have nice clothes on. I guess it's been thirty years since we didn't mount the spare this way
Evan
dougs #1206010 02/27/2017 1:10 AM
I just got done installing a Astro van cable winch system on my 37.
Jeff,
Would it be possible to provide some pics?
Bruce
1950 3100 5 Window
http://imgur.com/a/DAVYB
dougs #1206930 03/04/2017 11:26 PM
Sure did!! Used a brand new unit I bought from my Chevy dealer. They use pretty much the same style for the Chevy Astro van, pickups and Tahoes. It is a bolt on style. You can position the anchor point on top anywhere you want to clear your exahaust, etc. But the price sure did go up from when I did this 20 years ago on my 1952 compared to 3 years ago on my 1957 truck.
dougs #1206932 03/04/2017 11:46 PM
If you have a part number,year of Astro van/Tahoe or picture it would be very helpfull. Thanks
dougs #1206935 03/04/2017 11:48 PM
My truck is now at a friend garage since I have one of his cars in mine so I will get pics next week.
dougs #1206936 03/04/2017 11:51 PM
I'd search ebay probably get good price!
WOW! was I wrong, no bargains there either!!!
1946 1/2-Ton Chevy
dougs #1206938 03/04/2017 11:58 PM
It would be worthwhile to look in the junkyards and pick-n-pull places. A lot of the cables are stainless steel so they should work fine used.
dougs #1206943 03/05/2017 12:26 AM
I am going to check the price for a new one at the dealer since the one I got at the junkyard was a little crusty and should have been sandblasted,here in the rustbelt it gets very rusty under the spare tire since its not easy to clean it without dropping the tire.
dougs #1206972 03/05/2017 3:13 AM
Crusing in the Passing Lane
I put one under my 47.1 GMC pickup, seems like they were quite reasonable at yards.
Ed
