1 members (Russ_B_10),
91
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | Hello!
A friend of mine is restoring a 1947 (2nd Series) 1/2-ton pick-up (116 inch wheelbase), and he is having trouble with the emergency brake cables. The cables available from many of the suppliers, although listed as correct, do not work. Does anyone out there have any suggestions?
Randy Baumann | | | | | Joined: Dec 2013 Posts: 781 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 781 | Hi Randy, This sounds very familiar to me..... Here's a link to a thread with a solution towards the end. (CLICK) Let me know if you have any questions, good luck! | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | If you are talking the drum backing plate cable and housing, go with a replacement. If you just need the 1/8" cable of correct length anywhere, procure the cable and the ends can be put on as follows: Drill a quarter inch steel rod to 1/8 inch hole of proper length. Use a Nicopress tool and crimp twice or appropriately. Mig or Tig end
I have a large nicopress which does you lttle good but will help if possible. | | |
