2 members (Gdads51, UtahYork), 113 guests, and 3 robots.
Topics128,150
Posts1,056,985
Members48,460
#1206650 03/02/2017 10:09 PM
I can't seem to find my trucks make and engine size at the normal parts stores. NAPA does not even list a 261, Orielly only lists one for the 1960 truck, but returns no parts when I search (at least there was no oil filter). I tried some searches here for old threads, but I either get 1,000 returns, or 0, and skimming the thousand did not turn anything up.
Where do I go for items like plugs and wires and coils and oil filters and what not?
Thank you
1959 Chevy Viking. Belonged to my Great Grandfather
What type of oil filter unit?
Full-flow or by-pass filter?
These 1958 parts should work?
Check Rockauto.com for 1958 Chevrolet truck - 261 engine.
I think I use an AC-R43 on my 1959/1960 261s?
Thanks for the link.
As far as I can tell, it is the Full Flow. Looks pretty similar to this guy http://chevy.oldcarmanualproject.com/shop/1959trucksup/59ctsms0803.html
I really wanted to change the filter before starting it for the first time.
Tune-up parts for a 235 of the same year should work- - - -spark plugs, cap, rotor, wires, points and condenser, etc. should be a direct swap. If you pull the oil filter element and clean it up, you should be able to cross-reference whatever brand and number is in there now to something that's available currently. Last resort, just button up the canister without a filter element inside for the time being, just to get it running.
NAPA 1143 oil filter
Did a check on Rock Auto and no 261 listed for 1959. Do show one for 61 and 62 in the C-20. 58-62 are identical so here's what they show:
Condenser #DR60T $3.60
Points #9K5 2.40
Cap #5D1026 9.80
Rotor #4R1058 2.50
Wires #768 7.50
Coil #7B6 7.50
Ballast resister #RU10T 5.00
Oil filter #CH200PL 3.00
Quick scan shows a total of about $40
Evan
I was wondering if that was the case.
Thank you, and thanks to all that replied, this seems like a good site. I will probably need some gaskets and what not as well. Fuel filter too, who knows what else.
Thanks again
Points #9K5 2.40
Cap #5D1026 9.80
Rotor #4R1058 2.50
Wires #768 7.50
Coil #7B6 7.50
You should remove the condenser from the coil because it should not be connected to the negative distributor lead.
1951 1 Ton Completed
Is the full-flow filter or the by-pass filter.
NAPA filter #1141
AC PF141
Fram CH200PL
