9 members (Gdads51, Shaffer's1950, 78buckshot, Phak1, Leo, dt235sd, Jon G, mick53, 4tttt8),
87
Mod | | | Forums66 Topics128,181 Posts1,057,180 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | Well about a year ago I posted that I was going to try this on my 53 half T.. Well it worked. It took a lot of work and design. First I took a 94 chevy tilt column and grafted an 06 equinox electric pump to it. I went on E bay and bought the electric conversion box, about $65. I used all the parts from both columns to build it. A lot of measure and cut. With the electric conversion box, it gives the ability to adjust how easy or hard the steering will be. I used the original steering box to do this conversion. I cut the mast of and left 2" of shaft and milled a double D on it. I also used a steering damper on the straight axel to tie rod to take out any play. I'm very happy with this, works like a charm. This set up could very easily be added to a stock column with less work or an I didit column. If any one would like to try this, I would be willing to help you with more info. Contact me at : [email protected]. I hope this may help. The best to all, Steve | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Steve, write up a detailed tech tip and submit it to the Editor. That way it will help everyone wanting to do this conversion.
| | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | I am all for having a write up on it. I would love doing this on a stock column! | | | | | Joined: Aug 2014 Posts: 15 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 15 | I just got done doing this on my 49 stock column. Iam also doing a write up .Maybe by the end of the weekend . | | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | Any write-ups on this yet? | | |
